How to install kodi hebrew keyboard that works with wireless keyboard?
How I get the Hebrew keyboard works on kodi with wireless keyboard?
Did you try to change your keyboard layout in
settings → appearance → international : keyboard layout?
Not testet, but sounds promising :wink:
apparently this settings it’s working only for “Virtual” Keyboard… for example i have a ITALIAN Keyboard layout and apparently there’s no way for use the correct layout and only tha american/us layout it’s used for “hardware” keyboard.
I thinks it’s the same for wireless or bluethoot keyboard…
Yeah, sounds like it will not work.
Another guess:
sudo dpkg-reconfigure keyboard-configuration
Follow the prompts. Then restart your RasPi.
This will work in raspian, I gues it should also work on osmc.
Feedback is welcome :blush:
Lol… i have tryed it about one month ago… this is working for ssh session (now also all text it’s in italian) …not inside of kodi :slight_smile:
But wait some feedback… it’s possibly i have commit some error…
Thanks for all of you .
but I don’t success yet to enabled that keyboard .
I don’t have understand… you can’t use and you need to “enable” that keyboard ? It’s no cornern about layout ?
I suppose you have a working keyboard…you say work… and not enable :slight_smile:
