Hello!
How do you power on the Vero 4K? My cheap Android device flashed with Coreelec had a remote with a power button for turning the device on and off.
The Vero 4K remote does not appear to have a power button! Surely the only way to turn it on is not by physically disconnecting and reconnecting the power chord! ??
Also how do you shut down the Vero 4K with the remote (without having to laboriously navigate to the Power menu every time)?
Thanks.
