I have OSMC installed on my raspberry pi and i want to transfer videos from a usb to the sd card (the card that the OSMC is running on) i dont have a network connection
Sorry for bad english and Thanks in advance
Connect the USB Drive to the PI. If the USB Drive has it’s own power supply all should be ok, otherwise add max_usb_current=1 to /boot/config.txt (you can do that via MyOSMC) and ensure that your power supply provides at least 2A.
If that is the case then your drive is automatically mounted under /media/
You then either can use the kodi file manager or just copy from command line.
Thank you
