How to use apt-get upgrade to upgrade moonlight-embedded?
Hi, i use moonlight embedded and now i try to upgrade it but in osmc i cant use apt-get upgrade.
Anyone have a solution?
should be apt-get dist-upgrade.
I assume that with dist-upgrade, it will only update packages needed for OSMC.
Does it third-party tools include?
According to this page, it looks like moonlight-embedded needs the line:
deb http://archive.itimmer.nl/raspbian/moonlight jessie main
in /etc/apt/sources.list.
If it’s there, it should update.
dist-upgrade - updates all packages that upgrade does, plus osmc os packages. apt-get upgrade was disabled as it was leading to os breakages. If there is an update for moonlight-embedded in the repository, apt-get dist-upgrade will install it.
Thanks Tom
Okay. Thank you all!
