next time i planned to change from RASPBMC to OSMC
In Raspbmc i have some Video Add ons that are not existing in OSMC (actually)
Is it possible just to copy the related Add ons from the RASPBMC folder to the OSMC folder ?
If they are kodi addons from the repository, then they might work.
I know iPlayer does (limited to the same extent as with raspbmc)
Derek
Kodi is Kodi.
If certain addons were working in Kodi Helix on Raspbmc they should work on OSMC too. Just install them the same way you did on Raspbmc.
