Hi everyone, I’m new on OSMC, and I want to know if I can connect the R.PI with a Wifi hotspot with an authentification (usually, you enter the wifi password, a popup show up and you enter your username and password)
Thx for helping !
Thx for helping !
I recently ran into this.
I used the “Web Viewer” program to enter the required authentication after connecting to the wifi.
