How to run osmc included lircd with option --listen to accept TCP requests
and without option --uinput, to disable event forwarding ?
if i understand correctly, lircd is running from this script:
/var/run/lirc/lircd-lirc0.sh
i tried to modify it, but after reboot he returned to its original state…
But in the mean time, I think the helper has only been changed once or twice in like 3 years and it’s a 2 second fix (if you remember where it is! I keep a copy in my home dir so I can refind it)
Hello Sam and thank you for your reaction. The reason I am looking into the guts of LIRC is that my recent OSMC update broke it and I am still trying to figure out how to make it work (more on the topic is at Confusion regarding LIRC configuration). Later I found out that omitting --uinput did not really improve things for me but as I found the question here I thought I just might share it.
