Anybody up for a test? Please send me a pm.
I want to confirm that it works before making it public this time.
Be warned, there could still be some bugs…
You’ll need a raspberry pi 2 and not to be afraid of reinstalling your system if something goes wrong.
Hi there.
I’m up for a test. I have my current setup as an image so not bothered if anything goes wrong. I’m current using your script with snes, mame and ps1 roms.
Mcobit thank you for your work on retrosmc, please i’m up for a test too, please I am proud to collaborate on this project, although my knowledge of linux are low
I use your script with mame, n64, ps1, snes and my beloved msx
You just need to use xboxdrv as a daemon to emulate a keyboard for OSMC as you will find via a google search. then alter the retropie.sh script to stop the daemon, copy a new config file that supports retropie (as seen on this forum) and restart the daemon.
It really is simple one you have the two configs sorted.
Im happy to post my scripts but they are “hacked” and not quite as dynamic as they should be.
Right now, only retroarch emulators will work, the others are deactivated, but I will try to add them when I find the time
This is still up to date ?
Can you add a list of supported consoles ?
Cross out where not applicable : Atari 2600, NES, Game Boy, Game Boy color, Game Boy Advance, Super Nintendo, Master System, Megadrive (Genesis), FBA, iMame4all, PCEngine, MSX1/2, PSX, SegaCD, Sega 32x, Sega SG1000, Famicom Disk System.
This has an uninstallation option in the menu. It will remove the whole package if you don’t want to have it anymore,
but it will also remove any ROMS, BIOS, savefiles or configurationfiles you may have added or altered. So please make a backup of those if you want to use them later!
This is really clean after ? It will remove all installed packages too ? (dependencies install especially during this setup)
There will be a new version in the next days that will have a full retropie installation with all the emulators supplied by the retropie 3.0 SD image.
This will be completely removable as it uses a kind of “system in system” approach wich only occupies one folder.
There are three small packages that need to be installed to the main system. Everything else doesn’t alter the osmc system at all.
Please be a bit patient we are in private testing right now.
where do I add roms files to guys ? trying to add roms files in network-osmc-retropie-roms and everytime I click o a game it goes into back to kodi for a few seconds then back to emustation ???
@mcobit rpi 2 m8 that’s where I have copied them to but when I click the game it goes into kodi or like a stars all around you like traveling through a star field lol ??? don’t know where I installed it I just copied and pasted instructions into putty lol ??? I done /home/osmc/retropie /roms though network on my laptop is this correct ??
