Remote was working fine until I applied this update.
Any ideas?
Thanks.
Ignore, got it working. Had to go into My OSMC and re-select the remote profile.
I seem to have the same problem. After the update, no commands get through.
Would you mind telling me how to re-select the remote profile from ssh?
Hello,
same problem here with a logitech harmony (
but solved by selecting back the IR remote control
Olivier
I had the same issue. I used the IOS kodi remote app to run My OSMC and reselect the correct remote.
I plugged in a bluetooth keyboard and navigated using it to run My OSMC. Not sure how to do it through ssh.
Via ssh you need to change the link at /etc/lirc/lircd.conf to point to the wanted conf file. With WinSCP you can right click it and choose “Edit Link”
I went with the iOS app approach. I see via ssh that the link was modified. Back up and running,
Thanks for the help.
