I’ve been using OSMC on Raspberry 3 and Vero 4K for quite a while now without issues, usually for playing contents from German Mediathek.
Now I got another Raspi 3A+ with a SanDisk Class 10 SD card as the other devices have it as well. Especially when using the new device as HTSP client to a remote TVH server, I’m facing serious issues when I try to watch the (live) stream.
When switching to playback it usually does not display the stream, but commonly just an entirely black or alternatively grey or green colored screen or it does not even leave the TV guide overview page.
Since power supply is definitely fine and the SD card has no errors, could this be a performance issue with the SD card or are there known problems with the latest sw release?
Thx
Andreas
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Thanks for the hint w.r.t. the logging. Unfortunately, from a first glance at least I didn’t see anything suspicious. This time when hitting the play button, it started with audio, but showed only some kind of static wallpaper on the screen shortly afterwards.
http://paste.osmc.tv/hucanecomi
This line should be in your config.txt…
gpu_mem_512=144
Your currently only using 64MB and that might not be enough.
Thanks a lot. Adding this line above the existing gpu_mem_1024=… seems to have fixed the problem.
