Hi everyone,
edit: never mind the 4 blinks on the green LED, I just redownloaded OSMC and it’s gone.
This is my first experience using a Pi and I’m using a Pi2. I’d like to set up OSMC on an older tv that only has RCA output. My computer monitor’s HDMI port is broken, so my only possible monitor is the tv.
I’ve ordered this cable that should allow me to output to 3.5mm : http://www.dx.com/p/4-pin-3-5mm-minijack-to-3-x-rca-composite-av-cable-1-25-meter-10633#.VcC3icB_NBc
I’m installed OSMC to the Pi and powered it on, but all I get are weird moving colors on the TV (white and pink). It doesnt matter which cable (yellow, white, red) I plug into my yellow RCA input.
My question: is analog output switched on by default, and if not how can I turn on a headless display?
edit : I can access OSMC through SSH.
edit: I am using a 2A USB power supply.
edit: I’ve attached a picture of the weird colors on my TV. I get them whenever I connect one of the 3 composite cable to theyellow video input of the tv…
thanks!
