I have OSMC Installed on PI2 and want to install 3G Data Card on it.
Make : ZTE
Model : MF190
Thanks,
Inderjit.
Make : ZTE
Model : MF190
Thanks,
Inderjit.
So install it dont know what you expect from this community to magically popup and fix it for ya
here is a pro tip
google the shit outta it and read up on what you have to do then execute the plan and try come back when you fail atleast you can say that you atleast tried rather then expect us to do it for you.
I did look for this topic on Google and this forum but could not find any hints on how to install a data card on OSMC.
Just wondering if this is possible.
As your requirements are quite specific, what @Toast meant was that you should goggle in general information on how to get your card running under linux, test it and if it not work ask for specific help.
Here are some of the pages that come up:
https://wiki.archlinux.org/index.php/ZTE_MF110/MF190
Generally the steps are always the same:
Besides the driver your biggest challenge might be the last part of the dial up connection under OSMC as OSMC uses connman for it’s connectivity which may clash with the scripts described in the general webpages. So you might need to disable connman
The archwiki is the best place for information regarding devices i noticed over the years they often have detailed information regarding on how to get stuff working it just takes a little brainpower from the user to assemble the pieces and get it running
@bediinderjit if your search didnt yield archwiki you must have been searching for the wrong stuff cause the answer on your question is right there in black and white on how to get it working…
