Idle Vero V locks up after some 40-60 minutes
I can watch TV for hours without a problem. But lately, if I’m not watching TV, it dies within an hour. So far I’ve always just pulled the plug to restart it. Aside from the annoyance of resetting it every time I want to watch TV, I also use this box as a Logitech Media Server for my music player upstairs. So listening to music gets interrupted a lot.
The config has been stable and working fine for months. I did have an audio problem lately, but that was with the projector, and seems to have magically fixed itself. CPU and RAM usage are running at about 25% when the box is at idle (with Kodi running, unused), even with the Logitech Media Server serving music.
I thought it must be a problem such as a memory leak, but that doesn’t seem to be the case. Now I’m guessing that Kodi is the culprit, but the last update was a while ago. It is kind of annoying that Kodi is using 25% CPU while doing absolutely nothing.
FWIW, I’m getting the cecvtx kernel error every 10 seconds.
Thanks for the detailed instructions on getting the log files. So simple, even a computer engineer can do it!
Here’s the last bit from my ssh session, showing the two errors I got:
Grabbing log Kodi Log …
An error occurred while grabbing Kodi Log:
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xfc in position 5553: invalid start byte
Grabbing log Kodi Old Log …
An error occurred while grabbing Kodi Old Log:
Grabbing log provision …
Writing logs to temp file …
Dispatching logs …
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/lonexanake
Please try change the HDMI cable or port.
I tried another cable, going to another port on the projector. No joy.
Do you still get the CEC errors?
My workaround is to leave the TV running, with the projector turned off. This also seems to stop the cectx errors. So maybe the cectx errors are accumulating damage somehow. OTOH, both CPU and RAM remain at about 25% used, until it locks up.
I’ve noticed another problem, which might be related. I’m suddenly finding that videos are showing up as being about twice as long as they really are. For example, I watch a music video, that I’ve had for years, and is 4:04 long. The duration while playing says 10:22 or some such. When the video comes to an end after 4:04, it just sort of hangs there.
