Hello,
I am not sure if this is related to OSMC or Kodi itself, but I figured I’d write this here.
I would like to make a small suggestion for the widget system. I use the OSMC skin on Kodi on Linux.
I have two movie sources - one for internet livestreams (.strm files), one for actual movie files. These are assigned to two different menu items in the main menu.
If I assign the widget for either menu item to display just that source (namely: Videos > Sources > Video source example > Use as widget), the only available option under Artwork in the widget menu becomes Icon. The result is the following and it doesn’t look very appealing - I normally use posters here.
I suggest expanding the pool of available artwork for separate video sources to at least Poster and Fanart.
Thank you!
