I decided, yesterday, to do a clean install of the latest version on Vero.
I was surprised that the latest offered was for the 2015.06-1, but pushed ahead anyway.
The bootup of the SD Card was successful, except that the screen display had the right hand side cut, so that when the prompt to accept the licence conditions came, I couldn’t view or accept it.
As I’ve had this before, I SSH’d in and touch walkthrough_completed
- this allowed me to boot to the usual home screen, where I set about fixing the problem.
Settings|System|Video output was set to -
Windowed (no option to change, as it was blacked)
Resolution 1920x1080p
Refresh rate 60.0
I tried using the calibration, but the display already measured square, and no corner arrows were displayed - display still cut on RHS so no time visible.
Next I set resolution to 1280x70p, and adjusted the calibration.
Now I went back to information for the monitor, recorded when using RaspBMC -
[code]pi@raspbmc1:~$ /opt/vc/bin/tvservice -d edid.dat
Written 128 bytes to edid.dat
pi@raspbmc1:~$ /opt/vc/bin/edidparser edid.dat
Enabling fuzzy format match…
Parsing edid.dat…
HDMI:EDID version 1.3, 0 extensions, screen size 38x30 cm
HDMI:EDID features - videodef 0x80 !standby !suspend active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is DELL_E198FP
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 56-76 Hz, horizontal is 31-83 kHz, max pixel clock is 140 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred DMT detail timing format: 1280x1024p @ 60 Hz (35)
HDMI:EDID established timing I/II bytes are A5 4B 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x714F 8180 0101 0101 0101 0101 0101 81C0
HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 0
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 1
HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 7
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode initialised to DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 36864)
HDMI:EDID best score mode is now DMT (6) 640x480p @ 75 Hz with pixel clock 31 MHz (score 46080)
HDMI:EDID best score mode is now DMT (9) 800x600p @ 60 Hz with pixel clock 40 MHz (score 57600)
HDMI:EDID best score mode is now DMT (11) 800x600p @ 75 Hz with pixel clock 49 MHz (score 72000)
HDMI:EDID best score mode is now DMT (16) 1024x768p @ 60 Hz with pixel clock 65 MHz (score 94370)
HDMI:EDID best score mode is now DMT (18) 1024x768p @ 75 Hz with pixel clock 78 MHz (score 117964)
HDMI:EDID best score mode is now DMT (21) 1152x864p @ 75 Hz with pixel clock 108 MHz (score 174298)
HDMI:EDID best score mode is now DMT (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz (score 5260929)
HDMI:EDID DMT mode (36) 1280x1024p @ 75 Hz with pixel clock 135 MHz has a score of 196608
HDMI:EDID DMT mode (85) 1280x720p @ 60 Hz with pixel clock 74 MHz has a score of 135592
HDMI:EDID preferred mode remained as DMT (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz
HDMI:EDID has only DVI support and no audio support
edid_parser exited with code 0[/code]
This shows an optimum of 1280x1024p @60 Hz - which wasn’t in the vero/osmc list.
Q1) can I somehow force that mode?
Q2) is there a fix to avoid this in future? - I remember there was a discussion at the technical level about such problems and how the offered resolutions were to be selected.
Q3) any chance of TVservice or the equivalent for the vero?
In case this is relevant, the monitor is a Dell E198FP connected via a HDMI to VGA converter (works well with RaspBMC and OSMC and various Pi models)
Derek
