I’m trying to install for rpi on macOS but getting failures. I don’t see any issue in logfile.
Any thoughts what may have happened here?
Fri Aug 13 21:24:44 2021 OSMC Installer running on Mac OS X
Fri Aug 13 21:24:44 2021 Detected locale as en_IL
Fri Aug 13 21:24:44 2021 Attempting to load translation for locale en_IL
Fri Aug 13 21:24:44 2021 Could not load translation!
Fri Aug 13 21:24:44 2021 Resolving a mirror
Fri Aug 13 21:24:44 2021 Resolved mirror to Triple - Mirrors
Fri Aug 13 21:24:44 2021 Enumerating supported devices
Fri Aug 13 21:24:44 2021 Added the following devices
Fri Aug 13 21:24:44 2021 Vero 4K / 4K+
Fri Aug 13 21:24:44 2021 Vero 2
Fri Aug 13 21:24:44 2021 Raspberry Pi 1 / Zero
Fri Aug 13 21:24:44 2021 Raspberry Pi 2 / 3
Fri Aug 13 21:24:44 2021 Apple TV
Fri Aug 13 21:24:44 2021 Checking for updates
Fri Aug 13 21:24:44 2021 Checking for updates by downloading http://osmc.mirror.wearetriple.com/osmc/download//installers/latest_mac
Fri Aug 13 21:24:45 2021 Acquired mirror file
Fri Aug 13 21:24:45 2021 No new update is available
Fri Aug 13 21:24:50 2021 The user has selected English as their language
Fri Aug 13 21:24:50 2021 The user has selected Raspberry Pi 2 / 3 as their device
Fri Aug 13 21:24:50 2021 Attempting to download device versions file http://osmc.mirror.wearetriple.com/osmc/download/installers/versions_RBP2
Fri Aug 13 21:24:50 2021 Found a build called 2021.08-1
Fri Aug 13 21:24:50 2021 Found a build called 2020.11-1
Fri Aug 13 21:24:50 2021 Found a build called 2020.10-1
Fri Aug 13 21:24:50 2021 Found a build called 2020.06-1
Fri Aug 13 21:24:50 2021 Found a build called 2020.03-1
Fri Aug 13 21:24:50 2021 Found a build called 2020.01-1
Fri Aug 13 21:24:50 2021 Found a build called 2019.11-1
Fri Aug 13 21:24:50 2021 Found a build called 2019.10-1
Fri Aug 13 21:24:50 2021 Found a build called 2019.07-1
Fri Aug 13 21:24:50 2021 Found a build called 2019.06-1
Fri Aug 13 21:24:50 2021 Found a build called 2019.05-1
Fri Aug 13 21:24:50 2021 Found a build called 2019.04-1
Fri Aug 13 21:24:50 2021 Found a build called 2018.12-1
Fri Aug 13 21:24:50 2021 Found a build called 2018.10-1
Fri Aug 13 21:24:50 2021 Found a build called 2018.08-1
Fri Aug 13 21:24:50 2021 Found a build called 2018.07-1
Fri Aug 13 21:25:03 2021 The user has selected a local image for Raspberry Pi 2 / 3 with file location: file:///Users/offir.gonen/OSMC_TGT_rbp2_20210808.img.gz
Fri Aug 13 21:25:03 2021 Disabling internal install for device Raspberry Pi 2 / 3 as it does not support it
Fri Aug 13 21:25:05 2021 SD installation selected
Fri Aug 13 21:25:07 2021 Enumerating imageable devices for OSX
Fri Aug 13 21:25:07 2021 New disk device entry created with entry point /dev/rdisk0, 500.3 GB free space and label
Fri Aug 13 21:25:07 2021 =================================================
Fri Aug 13 21:25:07 2021 Starting to parse /dev/rdisk0 for additional info
Fri Aug 13 21:25:07 2021 MediaName-Line: Device / Media Name: APPLE SSD AP0512M
Fri Aug 13 21:25:07 2021 Protocol-Line: Protocol: PCI-Express
Fri Aug 13 21:25:07 2021 Determined PCI-Express as protocol for /dev/rdisk0
Fri Aug 13 21:25:07 2021 Decided to be a DMG: no
Fri Aug 13 21:25:07 2021 Ejectable-Line: Removable Media: Fixed
Fri Aug 13 21:25:07 2021 Determined Fixed as ejactableProperty for /dev/rdisk0
Fri Aug 13 21:25:07 2021 Decided that /dev/rdisk0 is not writable to us
Fri Aug 13 21:25:07 2021 Parsed device as NON-writable. NOT Appending.
Fri Aug 13 21:25:07 2021 Finished parsing additional info for /dev/rdisk0
Fri Aug 13 21:25:07 2021 New disk device entry created with entry point /dev/rd, Container Scheme free space and label
Fri Aug 13 21:25:07 2021 Starting to parse /dev/rd for additional info
Fri Aug 13 21:25:08 2021 Decided that /dev/rd is not writable to us
Fri Aug 13 21:25:08 2021 Parsed device as NON-writable. NOT Appending.
Fri Aug 13 21:25:08 2021 Finished parsing additional info for /dev/rd
Fri Aug 13 21:25:08 2021 =================================================
Fri Aug 13 21:25:08 2021 New disk device entry created with entry point /dev/rdisk2, 31.9 GB free space and label
Fri Aug 13 21:25:08 2021 Starting to parse /dev/rdisk2 for additional info
Fri Aug 13 21:25:08 2021 MediaName-Line: Device / Media Name: Storage Device
Fri Aug 13 21:25:08 2021 Protocol-Line: Protocol: USB
Fri Aug 13 21:25:08 2021 Determined USB as protocol for /dev/rdisk2
Fri Aug 13 21:25:08 2021 Decided to be a DMG: no
Fri Aug 13 21:25:08 2021 Ejectable-Line: Removable Media: Removable
Fri Aug 13 21:25:08 2021 Determined Removable as ejactableProperty for /dev/rdisk2
Fri Aug 13 21:25:08 2021 isEjectable: yes; isDmg: no; isReadOnly: no
Fri Aug 13 21:25:08 2021 Parsed device as writable. Appending.
Fri Aug 13 21:25:08 2021 Finished parsing additional info for /dev/rdisk2
Fri Aug 13 21:25:10 2021 Device selected: 2 /dev/rdisk2 31.9 GB Storage Device
Fri Aug 13 21:25:13 2021 EULA has been accepted
Fri Aug 13 21:25:13 2021 Extracting /Users/offir.gonen/OSMC_TGT_rbp2_20210808.img.gz
