Hi Sam,
Ok, I edited the Makefile and now I can run the make menuconfig command, here is the result->
`osmc@osmc:~/tbsdriver/media_build/v4l$ sudo make menuconfig
make -C /home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master -f /home/osmc/tbsdriver/media_build/v4l/Makefile.kernel config-targets=1 mixed-targets=0 dot-config=0 SRCDIR=/home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master v4l-mconf
make[1]: Entering directory ‘/home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master’
make -f /home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master/scripts/Makefile.build obj=scripts/kconfig hostprogs-y=mconf scripts/kconfig/mconf
HOSTCC scripts/kconfig/lxdialog/checklist.o
HOSTCC scripts/kconfig/lxdialog/inputbox.o
HOSTCC scripts/kconfig/lxdialog/menubox.o
HOSTCC scripts/kconfig/lxdialog/textbox.o
HOSTCC scripts/kconfig/lxdialog/util.o
HOSTCC scripts/kconfig/lxdialog/yesno.o
HOSTCC scripts/kconfig/mconf.o
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/mconf
make[1]: Leaving directory ‘/home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master’
make[1]: Entering directory ‘/home/osmc/tbsdriver/media_build/linux’
Syncing with dir …/…/media
Patches for 3.10.101-16-osmc already applied.
make[1]: Leaving directory ‘/home/osmc/tbsdriver/media_build/linux’
./scripts/make_kconfig.pl /home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master /home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master
Preparing to compile for kernel version 3.10.101
WARNING: This is the V4L/DVB backport tree, with experimental drivers
backported to run on legacy kernels from the development tree at:
http://git.linuxtv.org/media-tree.git.
It is generally safe to use it for testing a new driver or
feature, but its usage on production environments is risky.
Don’t use it in production. You’ve been warned.
V4L2_FLASH_LED_CLASS: Requires at least kernel 3.18.0
IR_NUVOTON: Requires at least kernel 3.12.0
RC_ST: Requires at least kernel 3.15.0
VIDEO_FB_IVTV: Requires at least kernel 3.11.0
DVB_PT3: Requires at least kernel 3.11.0
VIDEO_XILINX: Requires at least kernel 3.17.0
RADIO_SI4713: Requires at least kernel 3.13.0
I2C_SI4713: Requires at least kernel 3.17.0
VIDEO_ADV7604: Requires at least kernel 3.17.0
VIDEO_TC358743: Requires at least kernel 3.17.0
VIDEO_TVP5150: Requires at least kernel 3.17.0
VIDEO_MT9P031: Requires at least kernel 3.17.0
VIDEO_MT9V032: Requires at least kernel 3.19.0
VIDEO_SMIAPP: Requires at least kernel 4.0.0
VIDEO_ADP1653: Requires at least kernel 3.17.0
SOC_CAMERA_OV2640: Requires at least kernel 3.17.0
Created default (all yes) .config file
/home/osmc/osmc/package/kernel-osmc/src/vero2-linux-master/scripts/kconfig/mconf ./Kconfig
Your configuration changes were NOT saved.
./scripts/fix_kconfig.pl
And this is the screen that appear, what will I do now?
