I’m testing on Mint now… Can you not use the Win10 machine since your Ubuntu machine is being difficult?
No problems on Mint…
Thu Mar 2 21:32:29 2017 OSMC Installer running on Linux
Thu Mar 2 21:32:29 2017 Detected locale as en_US
Thu Mar 2 21:32:29 2017 Attempting to load translation for locale en_US
Thu Mar 2 21:32:29 2017 Could not load translation!
Thu Mar 2 21:32:29 2017 Resolving a mirror
Thu Mar 2 21:32:30 2017 Resolved mirror to http://osmc.mirror.triple-it.nl/osmc/download/
Thu Mar 2 21:32:30 2017 Enumerating supported devices
Thu Mar 2 21:32:30 2017 Added the following devices
Thu Mar 2 21:32:30 2017 Vero 4K
Thu Mar 2 21:32:30 2017 Vero 2
Thu Mar 2 21:32:30 2017 Raspberry Pi 1 / Zero
Thu Mar 2 21:32:30 2017 Raspberry Pi 2 / 3
Thu Mar 2 21:32:30 2017 Apple TV
Thu Mar 2 21:32:30 2017 Checking for updates
Thu Mar 2 21:32:30 2017 Checking for updates by downloading http://osmc.mirror.triple-it.nl/osmc/download//installers/latest_linux
Thu Mar 2 21:32:30 2017 Acquired mirror file
Thu Mar 2 21:32:30 2017 No new update is available
Thu Mar 2 21:33:57 2017 The user has selected English as their language
Thu Mar 2 21:33:57 2017 The user has selected Vero 4K as their device
Thu Mar 2 21:33:57 2017 Attempting to download device versions file http://osmc.mirror.triple-it.nl/osmc/download/installers/versions_VERO3
Thu Mar 2 21:33:57 2017 Found a build called 2017.02-2
Thu Mar 2 21:34:01 2017 The user has selected an online image for Vero 4K with build URL : http://osmc.mirror.triple-it.nl/osmc/download/installers/diskimages/OSMC_TGT_vero3_20170301.img.gz
Thu Mar 2 21:34:01 2017 This device does not support preseeding at all.
Thu Mar 2 21:34:01 2017 Disabling NFS install for device Vero 4K as it does not support it
Thu Mar 2 21:34:01 2017 Disabling USB install for device Vero 4K as it does not support it
Thu Mar 2 21:34:01 2017 Disabling SD install for device Vero 4K as it does not support it
Thu Mar 2 21:34:01 2017 Disabling internal install for device Vero 4K as it does not support it
Thu Mar 2 21:34:03 2017 SD installation selected
Thu Mar 2 21:34:03 2017 Running partprobe to inform operating system about partition table changes
Thu Mar 2 21:34:03 2017 Enumerating imageable devices for Linux
Thu Mar 2 21:34:03 2017 New disk device entry created with entry point /dev/sda, 500.1GB free space and label
Thu Mar 2 21:34:03 2017 New disk device entry created with entry point /dev/mmcblk0, 7861MB free space and label
Thu Mar 2 21:34:05 2017 Device selected: 36 /dev/mmcblk0 7861MB
Thu Mar 2 21:34:08 2017 EULA has been accepted
Thu Mar 2 21:34:08 2017 Downloading http://osmc.mirror.triple-it.nl/osmc/download/installers/diskimages/OSMC_TGT_vero3_20170301.img.gz
Thu Mar 2 21:46:57 2017 Download successful
Thu Mar 2 21:46:57 2017 Extracting /home/adam/OSMC_TGT_vero3_20170301.img.gz
Thu Mar 2 21:46:59 2017 Finished extraction. Going to write image
Thu Mar 2 21:46:59 2017 Requesting confirmation from user
Thu Mar 2 21:47:06 2017 User confirmed
Thu Mar 2 21:47:06 2017 Unmounting /dev/mmcblk0
Thu Mar 2 21:47:06 2017 Trying to unmount /dev/mmcblk0p1 at /media/adam/3DD3-5B39
Thu Mar 2 21:47:06 2017 Partition unmounted successfully, continuing!
Thu Mar 2 21:47:06 2017 Running partprobe to inform operating system about partition table changes
Thu Mar 2 21:47:06 2017 Writing /home/adam/OSMC_TGT_vero3_20170301.img to /dev/mmcblk0
Thu Mar 2 21:47:52 2017 Running partprobe to inform operating system about partition table changes
Thu Mar 2 21:47:52 2017 Image successfully written to device
Thu Mar 2 21:47:52 2017 Deleting the uncompressed image to save space
So seems to be some issue with your ubuntu machine.
I am trying my best to use windows less and learn Linux.
I will ask someone to read the thread from Linux Lite forums.
Maybe they will noticed what is wrong with it on the distro.
That’s a good thing
If you have another SD card on hand, try that. It will help to narrow down the problem.
Thank you for your patience.
It is solved now.
I used the same card and the osmc image d/l instead.
With Etcher on Linux Lite to flash the sd card with the osmc image, have tried the sd card and completed the install on Pi3 now
I’ll be able to use the osmc remote now for its intended use.
instead of adding lines into the terminal with it, and other experiments.
