Found a few posts on installing VPN on RPi, but nothing that looked definitive, and nothing on VyprVPN specifically. Has anyone done this and got some advice?
With this general Debian VPN guide, plus the VyprVPN OpenElec instructions, it should be possible.
Just add the pptp-client, then combine the two articles to get the required settings for VyprVPN into the right place on the client config.
https://brianhornsby.com/kodi_addons/openvpn will do the trick
We will eventually add VPN support directly in to My OSMC.
