I have Rpi2 and just updated from beta to Jun release. It tried to update itself, but said “Insufficient space” error, and after reboot i got the sad face. Had to do reinstall and turn off automatic update. I have 1GB SD card, is it too small or should it work with that?
That’s not big enough
Too small… 4gb is probably the bare minimum with 8gb being best recommendation.
Ok, thank you for responses. I’ll go and get me a bigger one.
