Hi guys,
I don’t know why, but frequently my TV is going on due to OSMC channel and CEC.
How can I find the reason ?
Thanks for your help.
Hi guys,
[quote=“raspdealer, post:1, topic:8697”]
Intempestive [/quote]
Word-a-day calendar?
It’s like each two days.
Which settings do you have enabled in Peripherals->CEC ?
“Switch source to this device on Startup” is on by default, if you have not already, switch that off.
Ok may be it’s due to ERROR > Reboot > TV ON ?
I’ll remove it but may be I should work on the error log instead ?
<settings>
<setting id="activate_source" value="1" />
<setting id="button_release_delay_ms" value="0" />
<setting id="button_repeat_rate_ms" value="0" />
<setting id="cec_hdmi_port" value="1" />
<setting id="cec_standby_screensaver" value="0" />
<setting id="cec_wake_screensaver" value="0" />
<setting id="connected_device" value="36037" />
<setting id="device_name" value="Kodi" />
<setting id="device_type" value="1" />
<setting id="double_tap_timeout_ms" value="300" />
<setting id="enabled" value="1" />
<setting id="pause_playback_on_deactivate" value="1" />
<setting id="physical_address" value="0" />
<setting id="port" value="" />
<setting id="send_inactive_source" value="0" />
<setting id="standby_devices" value="231" />
<setting id="standby_devices_advanced" value="" />
<setting id="standby_pc_on_tv_standby" value="36028" />
<setting id="standby_tv_on_pc_standby" value="0" />
<setting id="tv_vendor" value="0" />
<setting id="use_tv_menu_language" value="0" />
<setting id="wake_devices" value="231" />
<setting id="wake_devices_advanced" value="" />
</settings>
I still have the same issue.
If OSMC crashes when the TV is OFF, it will turn the TV ON on reboot.
