So I am using a freshly installed 2019 11 18 image. well dd’d onto a USB HD and resized to the full space. In the first scenario I use UUID and in the second scenario I use the device name. I think they both should use /dev/sda1 as root, but they do not. If you need any other outputs please ask.
Scenario 1:
osmc@osmc:~$ df -k Filesystem 1K-blocks Used Available Use% Mounted on devtmpfs 376668 0 376668 0% /dev tmpfs 381788 5216 376572 2% /run /dev/mmcblk0p2 3528640 930264 2399416 28% / tmpfs 381788 0 381788 0% /dev/shm tmpfs 5120 0 5120 0% /run/lock tmpfs 381788 0 381788 0% /sys/fs/cgroup /dev/mmcblk0p1 322936 26404 296532 9% /boot /dev/sda3 120047812 7445584 106481064 7% /media/Music /dev/sda2 120047812 61666708 52259940 55% /media/Movies /dev/sda1 120120804 936044 113063704 1% /media/00180154-fb7f-4643-9a01-01a4dfce2075 /dev/sda4 120050884 71625816 42303752 63% /media/TVShows tmpfs 76356 0 76356 0% /run/user/1000 osmc@osmc:~$ more /boot/cmdline.txt root=UUID=00180154-fb7f-4643-9a01-01a4dfce2075 rootfstype=ext4 rootwait quiet osmcdev=rbp2 osmc@osmc:~$ ls -l /dev/disk/bu-uuid ls: cannot access '/dev/disk/bu-uuid': No such file or directory osmc@osmc:~$ ls -l /dev/disk/by-uuid total 0 lrwxrwxrwx 1 root root 10 Jan 26 18:46 00180154-fb7f-4643-9a01-01a4dfce2075 -> ../../sda1 lrwxrwxrwx 1 root root 15 Jan 26 18:46 61B6-3000 -> ../../mmcblk0p1 lrwxrwxrwx 1 root root 10 Jan 26 18:46 dd7421ad-59ae-431d-a43e-c8db1857bb4f -> ../../sda2 lrwxrwxrwx 1 root root 10 Jan 26 18:46 e3f1aeb9-7d44-4a64-b907-3d9fe9362f9d -> ../../sda3 lrwxrwxrwx 1 root root 10 Jan 26 18:46 f1574921-690e-427c-86b8-1edd14979eee -> ../../sda4 osmc@osmc:~$
It is supposed to go to sda1 but it goes to mmcblk0p2
If I do this though
Scenario 2:
osmc@osmc:~$ df -k Filesystem 1K-blocks Used Available Use% Mounted on devtmpfs 376668 0 376668 0% /dev tmpfs 381788 5216 376572 2% /run /dev/sda1 120120804 936060 113063688 1% / tmpfs 381788 0 381788 0% /dev/shm tmpfs 5120 0 5120 0% /run/lock tmpfs 381788 0 381788 0% /sys/fs/cgroup /dev/mmcblk0p1 322936 26404 296532 9% /boot /dev/sda2 120047812 61666708 52259940 55% /media/Movies /dev/sda3 120047812 7445584 106481064 7% /media/Music /dev/mmcblk0p2 3528640 930248 2399432 28% /media/00180154-fb7f-4643-9a01-01a4dfce2075 /dev/sda4 120050884 71625816 42303752 63% /media/TVShows tmpfs 76356 0 76356 0% /run/user/1000 osmc@osmc:~$ more /boot/cmdline.txt root=/dev/sda1 rootfstype=ext4 rootwait quiet osmcdev=rbp2 osmc@osmc:~$ ls -l /dev/disk/by-uuid/ total 0 lrwxrwxrwx 1 root root 10 Jan 26 18:35 00180154-fb7f-4643-9a01-01a4dfce2075 -> ../../sda1 lrwxrwxrwx 1 root root 15 Jan 26 18:35 61B6-3000 -> ../../mmcblk0p1 lrwxrwxrwx 1 root root 10 Jan 26 18:35 dd7421ad-59ae-431d-a43e-c8db1857bb4f -> ../../sda2 lrwxrwxrwx 1 root root 10 Jan 26 18:35 e3f1aeb9-7d44-4a64-b907-3d9fe9362f9d -> ../../sda3 lrwxrwxrwx 1 root root 10 Jan 26 18:35 f1574921-690e-427c-86b8-1edd14979eee -> ../../sda4
It works!
