After viewing a video, the interface change to 720 or 480.
I have a Vero 4K+, which is connected to an AV (Denon AVR-X4300H), and the AV is connected to mt TV (Panasonic TX-55FZ800). All this with hdmi cables.
The interface’s resolution is 3840x2160. I also tried 1920x1080, with the same problem.
We recommend people with 4K TV’s set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
The settings we recommend are as follows…
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty)
Some televisions may also need, or benefit from, the following being set…
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
