Hey!
Trying to set up “ap-hotspot” on osmc.
However iptable_nat module is not in the kernel.
$iptables -t nat -A POSTROUTING -o wlan1 -j MASQUERAD
“iptables v1.4.21: can not initialize iptables table `nat ': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.”
Can I get the module iptable_nat in the next version ??
Some info.
$ls -alh /lib/modules/3.18.5-2-osmc/kernel/net/ipv4/netfilter/
drwxr-xr-x 2 root root 4,0K jan 1 1970 .
drwxr-xr-x 3 root root 4,0K mar 5 09:02 …
-rw-r–r-- 1 root root 5,9K feb 1 20:50 arptable_filter.ko
-rw-r–r-- 1 root root 23K feb 1 20:50 arp_tables.ko
-rw-r–r-- 1 root root 5,1K feb 1 20:50 arpt_mangle.ko
-rw-r–r-- 1 root root 6,4K feb 1 20:50 iptable_filter.ko
-rw-r–r-- 1 root root 6,3K feb 1 20:50 iptable_mangle.ko
-rw-r–r-- 1 root root 5,8K feb 1 20:50 iptable_raw.ko
-rw-r–r-- 1 root root 24K feb 1 20:50 ip_tables.ko
-rw-r–r-- 1 root root 4,8K feb 1 20:50 ipt_ah.ko
-rw-r–r-- 1 root root 6,0K feb 1 20:50 ipt_ECN.ko
-rw-r–r-- 1 root root 5,6K feb 1 20:50 ipt_REJECT.ko
-rw-r–r-- 1 root root 28K feb 1 20:50 nf_conntrack_ipv4.ko
-rw-r–r-- 1 root root 5,9K feb 1 20:50 nf_defrag_ipv4.ko
-rw-r–r-- 1 root root 9,9K feb 1 20:50 nf_log_ipv4.ko
-rw-r–r-- 1 root root 16K feb 1 20:50 nf_nat_h323.ko
-rw-r–r-- 1 root root 14K feb 1 20:50 nf_nat_ipv4.ko
-rw-r–r-- 1 root root 7,5K feb 1 20:50 nf_nat_pptp.ko
-rw-r–r-- 1 root root 6,1K feb 1 20:50 nf_nat_proto_gre.ko
-rw-r–r-- 1 root root 16K feb 1 20:50 nf_nat_snmp_basic.ko
-rw-r–r-- 1 root root 7,1K feb 1 20:50 nf_reject_ipv4.ko
$ uname -a
Linux osmc 3.18.5-2-osmc # 1 preempt the Sun on Feb 1 18:32:16 UTC 2015 armv6l GNU / Linux
Raspberry Pi Model B 1 +
bberski
