I have just received my Vero 2 and I’m trying to get the IR working. I have enabled the silver apple tv remote but nothing is happening. Am I missing something?
Ideally I want to integrate the Vero 2 into a setup I have using an RTi processor. The RTi uses IR to talk to the Vero 2 and I thought I would be able to use the IR codes for the silver apple TV remote.
Not yet – the earlier ‘Marches on’ update wasn’t really the complete update for this month. I’ll get amremote working shortly. We’ve fixed quite a few bugs and that’s taken some time so far.
We had to fix some other high priority issues first. We will release an update on Sunday. After this, I’ll look at integrating IR support. This won’t take long.
I added support for IR remotes a couple of weeks ago. This has been tested and seems to work well. It will be included in the next update, and you’ll be able to configure IR remotes via My OSMC -> Remotes as you can on other platforms.
