Is it Possible to install image on Pi over network with dd? [solved]
Apologies if this has been asked before.
My RPi is in an old PC midi tower case which I have to dismantle and
load the SDcard on my PC.
At the moment my image is corrupted (almost certain its the FAT /boot partition). OSMC does not run but I have ssh access to the raspberry pi
and can mount the card over my linux network.
ssh osmc@192.168.0.5 “lsblk”
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 149.1G 0 disk
├─sda1 8:1 0 20G 0 part /mnt/backup
├─sda2 8:2 0 20G 0 part /mnt/music
└─sda3 8:3 0 100G 0 part /mnt/video
mmcblk0 179:0 0 14.5G 0 disk
├─mmcblk0p1 179:1 0 243M 0 part /boot
└─mmcblk0p2 179:2 0 14.2G 0 part /
Where sda is an external connected hard drive on the Pi and mmcblk0 is the whole sd card.
I an wondering if this command could be used executed from local linux machine:
ssh osmc@192.168.0.5 “dd if = osmc_rbp2.img bs=4M of=/dev/mmcblk0”
osmc_rb2 would be the actual image name on the loacl machine, and mmcblk0 the sdcard on the remote Pi.
If not, I will just remove the sdcard and image using dd on a linux laptop.
Thanks in advance.
No. dd would be run by the OS on the card, would not find the image and anyway you are asking it to overwrite itself.
Thanks Graham, marking as solved.
