Is there a "FAST DELETE" Method anywhere?
I have a “tiny” issue.
Basically seems that Synology NAS will start adding index files everywhere. I have now disabled the offending feature but I keep finding files/directories and it would be nice to have a FAST way to get in there and delete the blighters.
But I guess it would come in useful for other stuff. I find for example I go off a series or something and simply want to blast it.
The workarounds are not painful - but are more laborious.
Be patient with me.
Very Very pleased with the 4K. Dropped the Amber Skin in as I preferred the menus - I’m an old fashioned IT guy - I like to see lists.
AND - Before I start doing things I should not
Will this work on a 4K? https://xbmcnut.blogspot.com.es/2012/07/exclude-eadir-directories-from-being.html
That should work fine.
