I stopped using it when all 3 HDMI ports on the TV broke. The TV itself still works perfectly if you plug the cable tv coax cable in. Just the HDMI seems to be broken.
Is it possible to somehow get flawless video 1080p playback and audio playback (on the TV speakers) working with the vero 4k utilizing other connectors the TV has?
edit: I know that CEC and stuff like that won’t work I just want to use the tv for some time before buying a 4k tv next year or so. And paying 150 + to fix the hdmi connectors seems a bad investment considering I plan to get a new tv soon-ish
Looking at the tv specs it looks like the tv supports 1080p over (HDMI™/Component) so i wonder could i run the vero 4k hdmi signal to a spliter that gives me component video and headphone jack audio ?
Sure I will test it. I hope i can get the cable locally buying online and waiting for it is a bit off putting specially if there is a chance it won’t work as intended
Thanks you guys are awesome ! Could you recommend any of this ? HDMI to YPbPr Component | eBay I’m from EU so getting stuff from the US takes ages and I have to pay extra tax once i get it. If I order something from inside the eu its fast and no extra cost.
