Hi, i installed my first OSMC (after having 5 raspbmc running)…
all looks good but i don’t have the settings menue?
thx
/W
thx
/W
Pressing down arrow?
thanks - is this a know bug for the mouse? – it is going via the XBMC remote app
Using the OSMC skin isn’t easy with a mouse as its designed for a remote and will work well with keyboard.
You have to remember that the user interface is Kodi (erstwhile XBMC), whatever the skin - and you can always select the Confluence skin (which makes mouse use easier)
Derek
