Are you seeing this in the logs or in MyOSMC? Because you won’t see it reported properly in MyOSMC.
I see it in MyOSMC…not sure how to see it in a log but I did put it in “normal” and applied the selection.
Am I supposed to contact @popcornmix myself? …sorry for late reply, I couldn’t post due to my new user account limit.
Odds are he has read this. He is likely only to reply if he as any suggestions.
- I haven’t looked at the issue in detail but can see some issues with the buffer in logs.
- Make sure you play back content from local storage to rule out throughput issues. I see some references to upnp:// in your logs.
Other than that, can you produce a small sample file which can be used to reproduce the problem?
I tried playing off HDD direct connect to raspberry pi 3… still won’t fast forward. I would love to send you a small file size of the movie but can you direct me how?
Upload it Dropbox or Google Drive if you can.
