Hello, I am having issues playing a specific file back. Everything else works (Over 30+ HEVC 4k UHD files). When I click the play button, estuary skin, blue circle comes up and then within a second it goes back to the information screen it doesn’t play.
I’m having issues lately with the newer 4k rips and h265 encodes. I think it has to do with the releases and how they’re ripped/encoded. I had some issues with Bohemian as you, Aquaman, and the latest Spiderman into the spider verse. The bottom black bar would be constantly flashing. For a couple I found another release and it seemed to be fine.
I tried taking screenshots but they were all garbled.
Will see if I can grab media info data and compare with yours.
If you want to pm me which release your bohemian was I can go find it and test on my end if you want.
At any rate, certainly seems to be some things being done differently with released yhat the Vero has issues with.
Ahh interesting. Weird because I also have the Apple TV 4K with Infuse, and infuse can play it without a problem however I lose ATMOS. My Mac can also play the file. I hope sam can address. It was a d3g release.
That would be because people copy command lines without understanding them. Someone once posted that they used --chromaloc 2 for their HDR encode, and now a lot of people do that. They don’t understand what it means, or why.
Also note that this encode doesn’t have the encode parameters as a stream comment. So, either they didn’t use x265 for the encode, or they specifically turned off that feature to hide their “special” command line.
As far as I know none really does 4k HDR encodes that would be even close to the quality standard we gotten used to from x264 720/1080p encodes over the last 8-10 years.
Also back in the day, there was no handbrake and one-click tools and working with avisynth and creating bat files with x246 instructions isn’t noob-friendly at all.
Not to mention cpu’s were much slower.
Today everyone thinks they can and should encode their own media even if they have no clue what they are doing rant over
