livin
12 March 2017 21:15
1
Hi Folks,
I again have fun after today’s update on rpi3
No update, and no wifi
Update:
get log from sd card
Log started: 2017-03-12 21:22:39
Selecting previously unselected package rbp-wifi-osmc.
Preparing to unpack …/rbp-wifi-osmc_1.0.0_armhf.deb …
Unpacking rbp-wifi-osmc (1.0.0) …
dpkg: error processing archive /var/cache/apt/archives/rbp-wifi-osmc_1.0.0_armhf.deb (–unpack):
trying to overwrite ‘/etc/firmware/BCM43430A1.hcd’, which is also in package rbp2-device-osmc 1.3.4
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack …/rbp2-device-osmc_1.3.6_armhf.deb …
Unpacking rbp2-device-osmc (1.3.6) over (1.3.4) …
Log ended: 2017-03-12 21:22:42
Post full logs.
I suspect you’re on the staging repository, rather than the release repository. The staging repository is experimental, and doesn’t come with any guarantee.
We haven’t publicly released any update today
livin
12 March 2017 22:20
3
sounds strange, because I’m waiting for fix of btPlayer since one month, and it does not come…
how to switch to release repo,in case if I’m in staging?
how to fix my issue?
Logs: http://paste.osmc.io/qememuyopu.vhdl
livin:
sounds strange, because I’m waiting for fix of btPlayer since one month, and it does not come…1) how to switch to release repo,in case if I’m in staging?2) how to fix my issue?
Unfortunately you’ve installed packages on your system which we can’t support, i.e.
/usr/bin/apt-get-real install --no-install-recommends bluetooth
OSMC already provides its own Bluetooth implementation. Things won’t work properly if you try and install Bluetooth packages manually.
I’d recommend a reinstallation.
livin
12 March 2017 22:33
5
I didn’t know this, because Bluetooth worked fine up to now.
What I have to remove or re-install now?
livin
12 March 2017 22:44
7
Not really if you are not doing KDE under freebsd on daily base
OSMC re-installation or package?
livin
12 March 2017 23:02
9
Oh, I will do so
thanks @sam_nazarko and @ActionA
