Updated today, seems like most of my files are no longer plain smoothly. This episode of Archer which works on two other installations just fine but when I try to watch it on the Vero it bounces around.
Edit, try to pull a log and it’s not giving me a correct URL through the uploading service.
Https://paste.osmc.tv/ html is what is being returned.
Edit got a log finally. Now files are not playing.
Https://paste.osmc.tv/axojiqeduz
Try changing Settings > Player > Adjust display refresh rate to On start/stop. That’s the recommended setting.
Ok did that, now I cannot watch anything, shuts down on me everytime i try to play anything. Wont let me upload log as well as it says it is too large. when I try to upload it gives me the html tag after the paste.osmc
Reboot twice to clear old logs from long uptimes, then demonstrate issue and upload.
http://paste.osmc.tv/irofobofep
There are my logs, my box is basically un-usable. It just reset my skin which was super cool. Any help is appreciated.
Have you tried disabling Hyperion and see if the problem still happens?
I have and no change. When that log was taken, Hyperion was active but it was not synced to my hue system, so it was dead.
I think I am going to wipe my box and start over with a fresh june update and see what happens.
Before you do that, try disabling the upnext service. That was the last thing logged.
