I still using RaspBMC, but I thought that I try OSMC but I can’t get it to work.
After writing the image to an SDcard and startup my Raspberry Pi 1 it shows:
- Formating device
- Installing files
- OSMS installed successfully
- (reboots)
- Kernel panic - not syncing: No working int found.
I tried creating new SDcard multiple times, but the same result.
(I’m happy that I kept my SDcard with RaspBMC.)
Not much info to go on there…
Which model of Pi 1 is it ? A, B, B+ ? 256MB or 512MB ?
What size SD card and have you tried a different one ?
I assume you chose an SD install not USB ?
Oh…, I’m sorry.
It’s an Raspberry Pi 1 Model B with 512 MB RAM, and an 8 MB SDcard.
(currently I don’t have another SDcard to try with)
Yes, I selected SD install, not USB.
Displayed on screen:
I really hope you mean 8GB not 8MB ??
If it can’t find init it means there is a problem with the file system or some of the system files were never copied during installation. My money is on a problem with the SD card.
Yes, of course it should have been 8GB.
I have now found an 4GB SDcard, and it seems to work with that one.
So it was most likely a bad SD-card.
