Thanks, for the suggestion, @sam_nazarko
I’m not entirely sure that those key presses from the numberpad are getting picked up.
I can’t seem to find a reference guide to CEC keymap codes, but I just did debug logging and used my TVs remote and I can easily see the key press for Blue and Green (which I have set to Info and ShowSubtitles), but when I press ‘1’ or ‘3’ on the numberpad, I don’t see those showing up?
Here’s what I see in a snippet of the log - while playing a video I pressed Green several times then tried pressing 1 and 3 and then pressing Blue. Would ‘1’ and ‘3’ show up in the CEC logging as ‘1’ ‘3’ or ‘one’ ‘three’?
2019-05-08 13:29:57.726 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:29:57.726 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:29:57.726 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:29:57.726 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:29:57.726 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:29:57.726 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:177.741
2019-05-08 13:29:57.726 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:29:57.726 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:29:57.740 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:29:57.740 T:4071112704 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
2019-05-08 13:29:57.753 T:4071112704 DEBUG: ------ Window Init (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:29:57.938 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:29:57.938 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:212ms
2019-05-08 13:29:57.938 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 212
2019-05-08 13:29:57.938 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:29:59.348 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:179.363
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:29:59.348 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:29:59.367 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:29:59.570 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:29:59.570 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:222ms
2019-05-08 13:29:59.570 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 222
2019-05-08 13:29:59.570 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:29:59.706 T:4071112704 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
2019-05-08 13:29:59.707 T:4071112704 DEBUG: ------ Window Deinit (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - >> 01:44:73
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F3 (green) (73) D:0ms cur:73
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73) current(ff) duration(0)
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - Changed key F3 (green) (73) D:0ms cur:ff
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73, 0)
2019-05-08 13:30:01.481 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 0
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:181.496
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - Key F3 (green): idle (duration:0) (73) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:01.481 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:01.494 T:4071112704 DEBUG: HandleKey: 252 (0xfc, obc3) pressed, action is ShowSubtitles
2019-05-08 13:30:01.536 T:4071112704 DEBUG: ------ Window Init (DialogNotification.xml) ------
2019-05-08 13:30:01.811 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:01.812 T:3755995872 DEBUG: CecLogMessage - key released: F3 (green) (73) D:331ms
2019-05-08 13:30:01.812 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 331
2019-05-08 13:30:01.812 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - >> 01:44:73
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F3 (green) (73) D:0ms cur:73
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73) current(ff) duration(0)
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - Changed key F3 (green) (73) D:0ms cur:ff
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73, 0)
2019-05-08 13:30:02.869 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 0
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:182.884
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - Key F3 (green): idle (duration:0) (73) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:02.869 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:02.870 T:4071112704 DEBUG: HandleKey: 252 (0xfc, obc3) pressed, action is ShowSubtitles
2019-05-08 13:30:03.201 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:03.202 T:3755995872 DEBUG: CecLogMessage - key released: F3 (green) (73) D:333ms
2019-05-08 13:30:03.202 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 333
2019-05-08 13:30:03.202 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:30:04.242 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:184.257
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:04.242 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:04.247 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:30:04.247 T:4071112704 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
2019-05-08 13:30:04.249 T:4071112704 DEBUG: ------ Window Init (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:04.461 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:04.461 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:219ms
2019-05-08 13:30:04.461 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 219
2019-05-08 13:30:04.461 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:05.296 T:4071112704 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:30:05.634 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:185.649
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:05.634 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:05.665 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:30:05.926 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:05.926 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:292ms
2019-05-08 13:30:05.926 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 292
2019-05-08 13:30:05.926 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:06.003 T:4071112704 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
2019-05-08 13:30:06.004 T:4071112704 DEBUG: ------ Window Deinit (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:06.751 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:30:06.751 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:30:06.751 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:30:06.751 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:30:06.751 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:30:06.752 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:30:06.752 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:186.767
2019-05-08 13:30:06.752 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:06.752 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:06.791 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:30:06.791 T:4071112704 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
2019-05-08 13:30:06.794 T:4071112704 DEBUG: ------ Window Init (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:07.053 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:07.053 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:301ms
2019-05-08 13:30:07.054 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 301
2019-05-08 13:30:07.054 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:09.965 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:30:09.966 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:30:09.966 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:30:09.966 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:30:09.966 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:30:09.966 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:30:09.966 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:189.981
2019-05-08 13:30:09.966 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:09.966 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:10.003 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:30:10.273 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:10.273 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:307ms
2019-05-08 13:30:10.273 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 307
2019-05-08 13:30:10.273 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:10.341 T:4071112704 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
2019-05-08 13:30:10.341 T:4071112704 DEBUG: ------ Window Deinit (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - >> 01:44:73
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F3 (green) (73) D:0ms cur:73
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73) current(ff) duration(0)
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - Changed key F3 (green) (73) D:0ms cur:ff
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73, 0)
2019-05-08 13:30:11.801 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 0
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:191.816
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - Key F3 (green): idle (duration:0) (73) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:11.801 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:11.838 T:4071112704 DEBUG: HandleKey: 252 (0xfc, obc3) pressed, action is ShowSubtitles
2019-05-08 13:30:11.879 T:4071112704 DEBUG: ------ Window Init (DialogNotification.xml) ------
2019-05-08 13:30:12.029 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:12.029 T:3755995872 DEBUG: CecLogMessage - key released: F3 (green) (73) D:228ms
2019-05-08 13:30:12.029 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 228
2019-05-08 13:30:12.029 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:14.594 T:4071112704 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
2019-05-08 13:30:22.260 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:30:22.261 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:30:22.261 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:30:22.261 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:30:22.261 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:30:22.261 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:30:22.261 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:202.276
2019-05-08 13:30:22.261 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:22.261 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:22.265 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:30:22.265 T:4071112704 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
2019-05-08 13:30:22.275 T:4071112704 DEBUG: ------ Window Init (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:22.595 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:22.595 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:334ms
2019-05-08 13:30:22.595 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 334
2019-05-08 13:30:22.595 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:30:23.953 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:203.969
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:23.953 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:23.975 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:30:24.183 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:24.183 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:229ms
2019-05-08 13:30:24.183 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 229
2019-05-08 13:30:24.183 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:24.275 T:4071112704 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
2019-05-08 13:30:24.276 T:4071112704 DEBUG: ------ Window Deinit (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - >> 01:44:71
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F1 (blue) (71) D:0ms cur:71
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71) current(ff) duration(0)
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - Changed key F1 (blue) (71) D:0ms cur:ff
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - key pressed: F1 (blue) (71, 0)
2019-05-08 13:30:27.594 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 0
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:207.609
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - Key F1 (blue): idle (duration:0) (71) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:27.594 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:27.604 T:4071112704 DEBUG: HandleKey: 254 (0xfe, obc1) pressed, action is Info
2019-05-08 13:30:27.604 T:4071112704 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
2019-05-08 13:30:27.607 T:4071112704 DEBUG: ------ Window Init (Custom_1109_TopBarOverlay.xml) ------
2019-05-08 13:30:27.812 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:27.812 T:3755995872 DEBUG: CecLogMessage - key released: F1 (blue) (71) D:219ms
2019-05-08 13:30:27.813 T:3755995872 DEBUG: PushCecKeypress - received key fe duration 219
2019-05-08 13:30:27.813 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - >> 01:44:73
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - SetCurrentButton F3 (green) (73) D:0ms cur:73
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73) current(ff) duration(0)
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - Changed key F3 (green) (73) D:0ms cur:ff
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - key pressed: F3 (green) (73, 0)
2019-05-08 13:30:31.415 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 0
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - CheckKeypressTimeout T:211.430
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - Key F3 (green): idle (duration:0) (73) timeout:875838001ms (rel:500,rep:0,prs:500,rel:0)
2019-05-08 13:30:31.415 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
2019-05-08 13:30:31.441 T:4071112704 DEBUG: HandleKey: 252 (0xfc, obc3) pressed, action is ShowSubtitles
2019-05-08 13:30:31.483 T:4071112704 DEBUG: ------ Window Init (DialogNotification.xml) ------
2019-05-08 13:30:31.635 T:3755995872 DEBUG: CecLogMessage - >> 01:45
2019-05-08 13:30:31.635 T:3755995872 DEBUG: CecLogMessage - key released: F3 (green) (73) D:221ms
2019-05-08 13:30:31.635 T:3755995872 DEBUG: PushCecKeypress - received key fc duration 221
2019-05-08 13:30:31.635 T:3755995872 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control release (45)
2019-05-08 13:30:34.241 T:4071112704 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
