Hello. I have osmc (kodi 16.1) on raspberry pi3. Works fine except for video library updating.
I use network source with protocol webdavs. I don’t use external sql. Video files are in separate folders. Folders names are as on imdb.com and often when updating - update is not correctly going on and I have
logs:
WARNING: Skipping item ‘davs://USERNAME:PASSWORD@webdav.:443/movies/’ with ‘.nomedia’ file in parent directory, it won’t be added to the library.
WARNING: Skipping item ‘davs://USERNAME:PASSWORD@webdav.:443/movies/Who%20Framed%20Roger%20Rabbit%20(1988)/’ with ‘.nomedia’ file in parent directory, it won’t be added to the library.
Network cloud server doesn’t have ‘.nomedia’ files in that folders.
I tried:
advancedsettings.xml
< advancedsettings >
< video >
< excludefromscan >
< regexp>[!-._ \/].nomedia[-._ \/]
< /excludefromscan >
< /video >
< videolibrary >
< usefasthash > false < / usefasthash >
< / videolibrary >
< /advancedsettings >
but without success. All the same.
If I update exact folder - it is updated with success.
So I have questions:
Does anybody know what wrong is with my updating process? Is there workaround ?
Is there better network protocol for network streaming of kodi then webdav like ftp or scp for ex. ?
I did’t try to avoid something and there’s actually no such file in that folder but kodi thinks there is - that’s the matter!
And I tried to mount webdav resource and to search .nomedia but without success:
mount -t davfs https://webdav. /mnt/webdav/
find /mnt/webdav -iname ‘nomedia’
I don’t understand why kodi thinks there’s .nomedia in “movies” folder when actually there’s no such file in that directory.
Any ideas ?
Well not 100% sure what are you trying to say. Do you have .nomedia in any of your directories (check top to bottom) and remember that a file starting with . would be a hidden file?
Surely the .nomedia file would not be recorded in the SQL database
“Well not 100% sure what are you trying to say. Do you have .nomedia in any of your directories (check top to bottom) and remember that a file starting with . would be a hidden file?”
Correct. no such file.
“Surely the .nomedia file would not be recorded in the SQL database”
I would think not also. but wanted to rule it out.
The library stopped adding new things about a week ago. Figured it was the scrappers. But to test I took kodi on the PC and cleared sources and started fresh. Added on folder and it scanned it but only show the networks of the shows. So I cleared it again and did it w/o SQL and no ftp (all media is on the pc). They all scanned fine. Searched SQL found nothing stopping it from scanning. Cleared Kodi again and added just the folders (no ftp) and test DB in SQL. Worked fine. Cleared it again and added sql and FTP. Back to the problem. Searched the FTP log and thats what it said
media (IPaddr)> MDTM Servers/filelocation/file_name.avi/.nomedia
Well that would indicate that you FTP server contains a .nomedia file.
Anyhow if you want to find whats going on enable debug logging and start the scan into library and then upload the logs files
This log file is not from OSMC so not sure what is the relation here? Anyhow the log clearly states “with ‘.nomedia’ file in parent directory, it won’t be added to the library.” so remove all your .nomedia files from your server and the items wiill be scanned correctly. Reminder:
.nomedia is a hidden file so you only will see it if you enable to via hidden files
The .nomedia can be in any directory that the video comes from (eg Servers or server1 or Dylan or Tv Shows or 13 Ghosts of Scooby-Doo, The or Season 01
sorry osmc is on my pi also, but am having the same issue on all builds. But testing on pc since I have access to folders from the drives and can rule out remote issues. He had posted this in many places but this happened to be the last place I can see the op was recent in. So figured this was the best bet to see if he resolved it. Also I know it clearly shows it but like op said. It’s not there. When I add the same thing via foldes and not ftp it scans fine. My hidden setting is on and I can see all files.
