Kodi crashed
Problem with Kodi on Vero OSMC last night.
I was watching this movie: Unique identifier: 756093261643262020041552024565162050 (0x919E46A3114A441E047C78B677A042) Full name: \WDMYCLOUD\Faubourg 36 (2008.).mkv Format: Matroska Format, Version: Version 4 File size: 2.36 GB Duration: 1 hour 55 minutes Overall bitrate: 2927 kb/s Frame rate: 25,000 fps Movie name: Faubourg 36 Encoding date: 2023-11-11 04:18:35 UTC Application used: mkvmerge v68.0.0 (‘The Curtain’) 64-bit Library used: libebml v1.4.2 + libmatroska v1.6.4
But on 2 occasions Kodi crashed with a green screen.
Can you please check the log and tell me why and how to get rid of this..
That log doesn’t have the crash contained in it so it is of limited use. You didn’t say if this was a persistent problem or if it was just this one file. If your primary concern is to just get through one problematic file you could try going into Kodi’s player settings and try it with hardware acceleration turned off.
Hello and thanks.
I did what you suggested, then played the video again right where the crash happened, and… no crash. Great!
Thanks again.
