This has been going on for at least a few days, but I just got annoyed enough with it to take steps to look into what’s going on. I’m trying to watch something on Netflix, but focus keeps getting dragged back to OSMC.
I enabled debug logging and switched to a different input to watch Netflix. Wasn’t a couple minutes in when OSMC pops back up. I quickly ssh in and do grab-logs -A. Here’s my debug logs.
While I type this OSMC crashed again. Here’s a new set of logs in case they help at all. Looks like almost exactly 10 minutes.
Edit: This part looks bad:
Jul 10 17:49:44 vero mediacenter[800]: kodi.bin: pthread_mutex_lock.c:349: __pthread_mutex_lock_full: Assertion `INTERNAL_SYSCALL_ERRNO (e, __err) != EDEADLK || (kind != PTHREAD_MUTEX_ERRORCHECK_NP && kind != PTHREAD_MUTEX_RECURSIVE_NP)’ failed.
Jul 10 17:49:44 vero sudo[2437]: pam_unix(sudo:session): session closed for user osmc
Jul 10 17:49:44 vero mediacenter[800]: /usr/bin/mediacenter: line 187: 2437 Aborted sudo -u osmc $KODI --standalone -fs --lircdev /var/run/lirc/lircd
Jul 10 17:49:44 vero mediacenter[800]: Kodi exited with return code 134 after 0 hours, 2 minutes and 42 seconds
It had something to do with seeking. Sometimes it would move the video forward, sometimes it wouldn’t? It was strange. Problem went away when I moved to v18, but I wasn’t expecting to be in Alpha this long.
If you haven’t added much to your library, you won’t be that bad off. The original library should not have been removed, so you can go back to 17. Only things changed since you updated to 18 will be missing.
