Today I experienced a non starting Kodi on my Rasberry Pi2B after i did some updating via ssh.
First i did
apt-get update
apt-get upgrade
which gave me a lot of updates which i installed.
During the update i was asked to keep or overwrite my php.ini (i think), which kept (original)
After that i forcely installed two packages that were hold back with apt-get upgrade:
armv7-network-osmc
rbp2-kernel-osmc
Then i started
apt-get autoremove
but cancelled the remove because of the warning
Then i rebooted and went on in ssh (not seen the screen) and the apt-get autoremove didn’t show anything to autoremove.
I tried apt-get install --reinstall rbp2-mediacenter-osmc but unfortunately didn’t solve my problem.
Reboot ends in a sad face while trying over and over with always the sad face as a result.
Your help will be greatly appreciated by my 4-year old daughter
This will break your system. You should run apt-get dist-upgrade to update, not upgrade. We introduced new dependencies in this update and apt-get upgrade will not fully acquire them.
May I interrupt. So Sam you say after the latest OSMC (2016.4-1) I can’t use apt-get upgrade anymore to keep my system up to date, I allways need to use apt-get dist-upgrade to get the actual stuff?
