I’ve just setup OSMC on my Raspberry Pi 2 Type B. Everything looks good except for a TV mini-serie called Pride and Prejudice. When I try to play one of its episode, Kodi remains on its GUI, pays the sound but doesn’t play the video.
Here are the details of the media file :
General
Unique ID : 209592872581041480811588272155059032799 (0x9DAE1E73130E92189FAE39F0885812DF)
Complete name : Pride and Prejudice (1995) - E01.mkv
Format : Matroska
Format version : Version 2
File size : 3.73 GiB
Duration : 55mn 42s
Overall bit rate : 9 579 Kbps
Encoded date : UTC 2013-01-10 22:46:09
Writing application : mkvmerge v5.6.0 (‘Kenya Kane’) built on May 27 2012 16:44:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 55mn 42s
Bit rate : 8 748 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.396
Stream size : 3.40 GiB (91%)
Title : Pride.and.Prejudice.1995.E01.720p.BluRay.DD5.1.x264-DON
Writing library : x264 core 120 r2164+656 2ff844c
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.03 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=16.8 / qcomp=0.65 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=3:0.90
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 55mn 42s
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 255 MiB (7%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : :00:00:00.000
00:10:34.592 : :00:10:34.592
00:21:37.963 : :00:21:37.963
00:30:04.594 : :00:30:04.594
00:39:32.912 : :00:39:32.912
00:48:56.851 : :00:48:56.851
I’ve also uploaded the full logs here : paste.osmc.io/hudukekiwi
Can someone tells me what’s going on with this file ?
Thanks in advance !
