I am using OSMC on a RPI3 connected to an LG TV. Since the last upgrade to “OSMC February 2017.02-2” my TV sometimes suddenly turns itself on due to Kodi restarting.
The OS uptime does not show a full reboot, but the system log reveals that kodi crashes, restarts and the HDMI port triggers the TV to start up. When I get up in the morning, the TV is turned on.
Log excerpt of the last crash this morning:
Feb 15 06:13:00 osmc mediacenter[276]: Error in `/usr/lib/kodi/kodi.bin’: corrupted double-linked list: 0x0496dcb8
Feb 15 06:13:00 osmc sudo[12523]: pam_unix(sudo:session): session closed for user osmc
Feb 15 06:13:00 osmc mediacenter[276]: Kodi exited with return code 134 after 4 hours, 40 minutes and 21 seconds
Feb 15 06:13:00 osmc kernel: Console: switching to colour frame buffer device 240x67 Feb 15 06:13:12 osmc mediacenter[276]: Starting Kodi…
Feb 15 06:13:12 osmc sudo[14383]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lir
Meanwhile I have installed a fresh copy of osmc, but kodi keeps crashing after a few hours, which wakes up the TV again and again. My TV now runs almost 24 hours a day if there’s nobody around to turn it off each time this happens
If the reason for the crash cannot be located, is there at least a way to prevent the TV from waking up through CEC when kodi restarts all the time?
Mar 03 09:28:11 tv-01 mediacenter[275]: ERROR: Exception caught on main loop. Exiting
Mar 03 09:28:12 tv-01 kernel: Unhandled prefetch abort: unknown 1 (0x001) at 0x7d202272
Mar 03 09:28:12 tv-01 sudo[1605]: pam_unix(sudo:session): session closed for user osmc
Mar 03 09:28:12 tv-01 mediacenter[275]: Kodi exited with return code 135 after 16 hours, 32 minutes and 56 seconds
Mar 03 09:28:12 tv-01 kernel: Console: switching to colour frame buffer device 240x67
Mar 03 09:28:23 tv-01 mediacenter[275]: Starting Kodi…
Mar 03 11:49:15 tv-01 mediacenter[275]: ERROR: Exception caught on main loop. Exiting
Mar 03 11:49:17 tv-01 sudo[1974]: pam_unix(sudo:session): session closed for user osmc
Mar 03 11:49:17 tv-01 mediacenter[275]: Kodi exited with return code 132 after 2 hours, 20 minutes and 54 seconds
Mar 03 11:49:17 tv-01 kernel: Console: switching to colour frame buffer device 240x67
Mar 03 11:49:28 tv-01 mediacenter[275]: Starting Kodi...
Mar 04 05:50:35 tv-01 sudo[327]: pam_unix(sudo:session): session closed for user osmc
Mar 04 05:50:35 tv-01 mediacenter[280]: Kodi exited with return code 139 after 15 hours, 0 minutes and 5 seconds
Mar 04 05:50:35 tv-01 kernel: Console: switching to colour frame buffer device 240x67
Mar 04 05:50:46 tv-01 mediacenter[280]: Starting Kodi...
you are not alone.
I have the same problem on a samsung tv.
been trying to get proper logs for ages.
I suspected some addon was the culprint but it doesn’t seem like it since you did a clean install.
