Hello,
When I try to update using OSMC after reboot it ends in error. When I do manually I get this:
$ sudo apt-get update Ign:1 http://ftp.debian.org/debian stretch InRelease Ign:2 http://security.debian.org stretch/updates InRelease Ign:3 http://apt.osmc.tv stretch InRelease Ign:4 http://ftp.debian.org/debian stretch-updates InRelease Err:5 http://security.debian.org stretch/updates Release Something wicked happened resolving 'security.debian.org:http' (-5 - No address associated with hostname) Err:6 http://apt.osmc.tv stretch Release Something wicked happened resolving 'apt.osmc.tv:http' (-5 - No address associated with hostname) Err:7 http://ftp.debian.org/debian stretch Release Something wicked happened resolving 'ftp.debian.org:http' (-5 - No address associated with hostname) Err:8 http://ftp.debian.org/debian stretch-updates Release Something wicked happened resolving 'ftp.debian.org:http' (-5 - No address associated with hostname) Reading package lists... Done E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://apt.osmc.tv stretch Release' does no longer have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://ftp.debian.org/debian stretch Release' does no longer have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://ftp.debian.org/debian stretch-updates Release' does no longer have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
$ sudo apt-get dist-upgrade
Reading package lists⌠Done
Building dependency tree
Reading state information⌠Done
You might want to run âapt --fix-broken installâ to correct these.
libperl5.24 : Depends: perl-modules-5.24 (>= 5.24.1-3+deb9u6) but 5.24.1-3+deb9u5 is installed
perl : Depends: perl-base (= 5.24.1-3+deb9u6) but 5.24.1-3+deb9u5 is installed
E: Unmet dependencies. Try âapt --fix-broken installâ with no packages (or specify a solution).
and when I do that:
$ sudo apt --fix-broken install
Correcting dependencies⌠Done
The following additional packages will be installed:
perl-base perl-modules-5.24
2 upgraded, 0 newly installed, 0 to remove and 34 not upgraded.
3 not fully installed or removed.
Need to get 3964 kB of archives.
After this operation, 0 B of additional disk space will be used.
Err:1 http://ftp.debian.org/debian stretch/main armhf perl-base armhf 5.24.1-3+deb9u6
Something wicked happened resolving âftp.debian.org:httpâ (-5 - No address associated with hostname)
Err:2 http://ftp.debian.org/debian stretch/main armhf perl-modules-5.24 all 5.24.1-3+deb9u6
E: Failed to fetch http://ftp.debian.org/debian/pool/main/p/perl/perl-base_5.24.1-3+deb9u6_armhf.deb Something wicked happened resolving âftp.debian.org:httpâ (-5 - No address associated with hostname)
E: Failed to fetch http://ftp.debian.org/debian/pool/main/p/perl/perl-modules-5.24_5.24.1-3+deb9u6_all.deb Something wicked happened resolving âftp.debian.org:httpâ (-5 - No address associated with hostname)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
And then Iâm really at a loss. Somehow, uploading log files doesnât work either ? Something about unable to find URL.
So I did a copy and paste :
http://paste.osmc.io/toxugejido.vhdl
I hope I supplied sufficient information for you to work with!
Morgan.
