it’s better to have a fix rather for crash than for disabling
can you say how to enable/disable it from command line?
thx
Hi @sam_nazarko
finally I find a time to have a look inside of service.py of btplayer.
So the issue in line 145:
elif iface == "MediaTransport1":
if "State" in changed:
if not changed["State"] == self.state:
self.state = changed["State"]
if not self.state == "active":
xbmc.stopBTPlayer()
When I started video first time the condition
returned false
Then I pressed pause, after 1-2 mins it run stopBTPlayer where same condition gave true and kodi crashed on xbmc.stopBTPlayer()
I extended the code with log messages
log("Enter 1")
log("Enter 2")
if not self.state == "active" and xbmc.isBTPlayerActive():
log("Enter 3")
xbmc.stopBTPlayer()
log("Enter 4")
and got following:
15:14:49.695 T:1523577840 DEBUG: BTPlayer: Enter 1
15:14:49.695 T:1523577840 DEBUG: BTPlayer: Enter 2
15:14:49.695 T:1523577840 DEBUG: BTPlayer: Enter 3
15:14:49.706 T:1958653952 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
15:14:49.706 T:1958653952 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
15:14:49.727 T:1958653952 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
15:14:49.727 T:1958653952 DEBUG: ------ Window Init (Home.xml) ------
15:14:49.780 T:1958653952 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
15:14:49.781 T:1958653952 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
15:14:49.781 T:1913648112 DEBUG: Thread JobWorker start, auto delete: true
15:14:49.781 T:1958653952 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
15:14:49.781 T:1958653952 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
15:14:49.789 T:1642066928 DEBUG: Thread JobWorker start, auto delete: true
15:14:52.478 T:1958653952 NOTICE: CVideoPlayer::CloseFile()
15:14:52.478 T:1958653952 NOTICE: VideoPlayer: waiting for threads to exit
15:14:52.478 T:1419740144 NOTICE: CVideoPlayer::OnExit()
15:14:52.478 T:1419740144 NOTICE: Closing stream player 1
15:14:52.478 T:1419740144 NOTICE: Waiting for audio thread to exit
15:14:52.479 T:1316668400 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
15:14:52.479 T:1316668400 NOTICE: thread end: CVideoPlayerAudio::OnExit()
15:14:52.479 T:1316668400 DEBUG: Thread VideoPlayerAudio 1316668400 terminating
15:14:52.479 T:1419740144 NOTICE: Closing audio device
15:14:52.479 T:1419740144 DEBUG: CDVDAudio::Flush - flush audio stream
15:14:52.480 T:1934033904 DEBUG: CActiveAE::DiscardStream - audio stream deleted
15:14:52.480 T:1934033904 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
15:14:52.483 T:1419740144 DEBUG: Previous line repeats 3 times.
15:14:52.483 T:1419740144 NOTICE: Deleting audio codec
15:14:52.483 T:1419740144 NOTICE: Closing stream player 2
15:14:52.484 T:1419740144 NOTICE: waiting for video thread to exit
15:14:52.484 T:1325057008 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
15:14:52.484 T:1325057008 NOTICE: thread end: video_thread
15:14:52.484 T:1325057008 DEBUG: Thread VideoPlayerVideo 1325057008 terminating
15:14:52.486 T:1419740144 NOTICE: deleting video codec
15:14:52.493 T:1411351536 DEBUG: Thread FileCache 1411351536 terminating
15:14:52.504 T:1419740144 DEBUG: OnPlayBackStopped: play state was 2, starting 0
15:14:52.508 T:1419740144 DEBUG: Thread VideoPlayer 1419740144 terminating
15:14:52.508 T:1958653952 NOTICE: VideoPlayer: finished waiting
15:14:52.508 T:1958653952 DEBUG: DeleteRenderer - deleting renderer
15:14:52.508 T:1958653952 DEBUG: CMMALRenderer::~CMMALRenderer
15:14:52.508 T:1958653952 DEBUG: CMMALRenderer::UnInitMMAL
15:14:52.533 T:1958646768 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
15:14:52.533 T:1958646768 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
15:14:52.539 T:1299891184 DEBUG: CMMALRenderer::Process - stopping
15:14:52.539 T:1299891184 DEBUG: Thread MMALRenderer 1299891184 terminating
15:14:52.558 T:1958653952 DEBUG: CMMALPool::~CMMALPool Destroying pool 0x5b468f00 for port vc.ril.video_decode:out:0(OPQV)
15:14:52.562 T:1308279792 DEBUG: CMMALRenderer::Run - stopping
15:14:52.562 T:1308279792 DEBUG: Thread MMALProcess 1308279792 terminating
15:14:52.563 T:1523577840 DEBUG: BTPlayer: Enter 4 xbmc.stopBTPlayer()
kodi crash happened exactly on
I also tried to extend else condition to xbmc.isBTPlayerActive() and had no more crash
xbmc.stopBTPlayer()
Unfortunately my knowledge of xbmc and dbus is close to zero, so if you have any ideas please help
Thanks!
cc @gezb @matejmosko
Looks good – let me know if this continues to work.
Hi @sam_nazarko
I’ve made pull request with extended “idle” status in addition to “active”:
For me now it works perfectly, but I’m using osmc with streaming in direction OSMC => a2dp => bluetooth speaker.
It would be nice if you can test it also for scenario “bluetooth audio => osmc” and switching between OSMC => bluetooth and bluetooth => OSMC
Thanks.
