Recently was prompted to update my vero 4K+ box to the latest software. After doing so all my movies have lip sync issues? The audio seems delayed and is “behind” the video.
Need help!
Thanks!
Need help!
Thanks!
Well we need logs to help
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Further, do you know which version you were last on?
Scratch that guys! I had recently activated the MusicCast feature on my Yamaha preamp and it was linked with my other Yamaha bedroom receiver which caused the lip sync issues. By unlinking them all is good!
