I have a 6 month old Vero 4K and the blue power LED seems to be dying. It usually stays off, but sometimes flickers which is super annoying.
What should be my course of action?
Thanks.
Thanks.
Do you care about the blue LED? I know a lot of people were actually looking for ways to disable this and when theirs failed (Still not that common a fault but it has happened before) they were actually pretty happy about it.
Nothing else will break, but we can replace the LED under warranty if you’d like
If it’s purely a cosmetic issue, I probably won’t bother to send it all the way back to the UK to get fixed. I’ll put some tape over it until it stops flickering and finally dies.
Thanks.
Nothing else will go wrong.
