I don’t know if it’s an issue only affecting me, but I can select only “raspberry pi” in the linux installer. I have try the windows one and I can see raspberry 1 and 2 for select.
Try updating the installer.
That did it for med.
sudo apt-get update
sudo apt-get upgrade osmc-installer
You may need to force a re-install. I found a small bug causing the package version not to upgrade properly on Debian
I use OpenSuse 13.2, with the last version of the app (from github). Also have try with the official rpm from 13.1, but I didn’t see raspi2 in the installer.
zypper addrepo http://download.opensuse.org/repositories/home:osmc/openSUSE_13.2/home:osmc.repo
zypper refresh
zypper install osmc-installer
With the recently added repo for Opensuse 13.2 now is showing raspberry 2. Thanks Sam
