I have successfully used remote control on Raspbian. Howerver, if I just copy the config files I have used, every event is omitted twice. I have been trying to fix it and as the result it does not work now.
Could you please post official config guide for lirc? I have found kodi.bin process with some lirc arguments. But have no idea, whether there is in it lirc support.
It is weird, becase if I try to press the button really shortly, I sometimes manage to press it just once, but on Raspbian it worked without no problems.
EDIT: hey, I just realised that it changes my /boot/config.txt, I delete some line and after reboot it is there again.
I am using RC3,
It would be helpful if you posted a copy of your lircd.conf file before you edited it and it stopped working.
Also a copy of your config.txt.
Can you also confirm what type of IR receiver you are using ? Is it GPIO or USB based ?
Thanks for reply.
begin remote
name Y0400052
bits 16
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9066 4504
one 587 1661
zero 587 539
ptrail 592
repeat 9056 2233
pre_data_bits 16
pre_data 0xC03F
gap 108081
toggle_bit 0
begin codes
KEY_ESC 0xF20D # Was: MENU
SQUARES 0x8A75
CH_SURF 0x4AB5
KEY_L 0xCA35 # Was: l
KEY_AUDIO 0xD827 # Was: AUDIO
KEY_POWER 0x00000000000000FF # Was: POWER
KEY_TV 0x0000000000006A95 # Was: TV
KEY_RADIO 0x000000000000EA15 # Was: FM
SCAN 0x000000000000A857
DISPLAY 0x0000000000006897
KEY_1 0x000000000000A05F # Was: 1
KEY_2 0x000000000000609F # Was: 2
KEY_3 0x000000000000E01F # Was: 3
KEY_4 0x000000000000906F # Was: 4
KEY_5 0x00000000000050AF # Was: 5
KEY_6 0x000000000000D02F # Was: 6
KEY_7 0x000000000000B04F # Was: 7
KEY_8 0x000000000000708F # Was: 8
KEY_9 0x000000000000F00F # Was: 9
KEY_0 0x00000000000048B7 # Was: 0
KEY_TAB 0xC03F
KEY_AGAIN 0x0000000000008877 # Was: RECALL
KEY_ENTER 0x000000000000C837 # Was: ENTER
KEY_DVD 0x1AE5 # Was: DVD
ZZ 0x02FD
CC 0x000000000000F807
MTS 0x000000000000D827
FINE_DOWN 0x0000000000009867
FINE_UP 0x00000000000018E7
KEY_VIDEO 0x0000000000007887 # Was: VIDEO
KEY_MUTE 0x00000000000028D7 # Was: MUTE
KEY_UP 0x00000000000030CF # Was: CH_UP
KEY_DOWN 0x00000000000008F7 # Was: CH_DOWN
KEY_LEFT 0x00000000000010EF # Was: VOL_DOWN
KEY_RIGHT 0x00000000000020DF # Was: VOL_UP
KEY_F11 0x000000000000C03F # Was: FULLSCREEN
KEY_SLEEP 0x00000000000004FB # Was: SLEEP
BOSS_KEY 0x000000000000926D
KEY_RED 0x000000000000D22D # Was: RED
KEY_GREEN 0x00000000000032CD # Was: GREEN
KEY_YELLOW 0x000000000000B24D # Was: YELLOW
KEY_BLUE 0x000000000000728D # Was: BLUE
PIP 0x00000000000052AD
KEY_DOT 0x000000000000827D # Was: .
KEY_BACK 0x0000000000002AD5 # Was: BACK
KEY_PLAY 0x000000000000C23D # Was: PLAY
KEY_NEXT 0x000000000000AA55 # Was: NEXT
KEY_F 0x22DD # Was: FFWD
KEY_R 0x42BD # Was: REW
TIMESHIFT 0x000000000000A25D
KEY_STOP 0x000000000000629D # Was: STOP
KEY_RECORD 0x000000000000E21D # Was: REC
KEY_RECORD 0x629D # Was: REC_STOP
SNAPSHOT 0x00000000000012ED
KEY_ESC 0x0AF5 # Was: CLEAR
KEY_M 0xF20D # Was: MENU
end codes
end remote
I have also tried lircrc:
begin
button = KEY_LEFT
prog = irexec
repeat = 0
delay = 5000
config = echo "a" > /var/tmp/log
end
It is GPIO remote control. Is it not original, I have bought some IR recevier from eBay, but worked perfectly.
I added at the end of the config.txt:
dtoverlay=lirc-rpi,gpio_in_pin=27
EDIT: Ok, it is working now, but still each key is pressed twice. I reconnect it to the pin 18, other config is the same.
Hey, that is weird.
After next boot it did not want to start OSMC environment - just some sad face and nothing. Over ssh: sudo command disappeared!!! and OSMC screen would not run until I ran systemctl stop lirc
Sounds like you have underlying problems with your system - a problem with lirc is not going to cause the sudo command to stop working or Kodi to crash.
If possible please use the log uploader to upload full debug logs.
Here it is:
http://paste.osmc.io/orikoruleq
dmesg:
http://paste.osmc.io/sagofeqoho
I don’t see in this log the line with dtoverlay…, but in /boot/config.txt it is.
