On HD-channels the subtitles is placed to the left middle of screen watching Live-TV, and is also very tiny. On SD -channels the subs is placed just as it supposed of normal font size at the lower centre of screen.
I’m using Tvheadend PVR addon.
Any ideas?
Example
Termo
21 August 2015 14:12
2
this is the same issue as I reported a week ago - no comments sadly
PVR subtitles are smaller than before the upgrade to Isengard and they are now placed a bit up and to the left?!? I just tried Isengard on my Ubuntu laptop and there it works as expected.
Also changing resolution does not change anything, and subtitles on movies and tv-shows works as normal.
How can I downgrade different packages for testing purposes?
This seems to be a general KODI releated problem with several PVR addons due to posts in the KODI forum.
Termo
6 September 2015 16:03
4
I think the issue is fixed by https://github.com/xbmc/xbmc/pull/7878
Can it be implemented into OSMC soon as well??
For me it is now working as supposed since a weak back or something like that.
Edit: problem persists.
Termo
6 September 2015 18:16
6
Are you sure? I still have it (just tested again to be sure with a fully updated OSMC), but it has always for me only been on HD streams.
Sorry. When I tested, it was sd-material casted on a HD-channel that fooled me.
Still have this error. Nothing new?
another thread for same error
Seems to work as supposed now.
