Dear Community,
We are working with IKUSI Flow IPTV Streaming Server. This is a nice server that can get DVB-S/2 complete transponders and convert them to UDP Multicast Streams.
We have configured 52 channels on various transponders and we have created an M3U file that has each channel on the following form:
#EXTINF:0,CNN Int.
udp://@239.255.24.1:1234
The list created has no problem playing on my Macbook’s VLC and Kodi installations. When I open it on the Raspberry PI 2, all 51 channels are correctly displayed instead of the CNN stated above!
The problem is when I watch in full screen another channel and then use the UP and Down buttons on the remote to go to CNN, I can hear audio but the video is full of horizontal lines.
When I see the channels minimized on the list and change to CNN and other channels there is no problem!!!
When I start the CNN before any other channel in full screen and then try to change channel, I get the sad little face and the Kodi restarts.
I have enabled debugging and I get the following errors when I change every channel:
ffmpeg[5E9FF3F0]: [mpeg2video] Invalid frame dimensions 0x0.
What is this error? What is the number inside the [brackets]?
I also get the following errors:
FactoryCodec - Video: mmal-mpeg2 - Failed
CMMALVideo::Open Codec mmal-mpeg2 is not supported
I have tried so many options but no solution.
Can you help me please?
