after the latest (I think) osmc update, my Logitech Harmony Ultimate One is acting in a weird way.
most annoying thing is, each time I launc kodi/osmc, when I press the central OK button it seems it is receiving like 3 or 4 clicks quickly.
I also have problems sometimes with the responsiveness of the remote.
it was working fine before, is there any settings I can try to make it work better?
also: which is the correct mini jack port on the Vero4K for the IR extender?
thanks
What version did you update from?
Has the Harmony received any updates?
I updated from the december update to the latest one. or whatever it was before that, I always keep my vero4k updated.
the Harmony wasn’t updated, in fact it’s months since I lastly synced it to its software.
Has something changed in your environment?
Last remote changes were around June
I remember having looked here some time ago and I changed something in the remote prefs (osmc menu) but didn’t improve.
What can I do now?
Hard to speculate without knowing more info.
Have you checked the obvious things like batteries etc?
the remote is in charging every night in its dock
is there any log or something I can send you so you could check?
Yes – you can send some logs via My OSMC.
